Fordson Tractors Discussion Forum
fordson major: exhaust valves caps
Diederik
12-11-2005 03:11:48
what can happen when i run my engine without those caps on top of the exhaust valve stems?? what is the reason of those caps?
Bob
12-11-2005 10:09:10
 Re: fordson major: exhaust valves caps in reply to Diederik, 12-11-2005 03:11:48
The cause the valve to be free of the keeper, as it opens, allowing it to rotate a bit.
This helps keep the heat and wear on the valve even to prevent valve "burning". This would be most important on a heavily-worked tractor.
Are you missing some? As of a couple of years ago, FNH still had them available.
