Super dexta starter motor
Dave W
01-25-2000 09:18:59
My '64 super has one high current lead to the starter motor, but there appears to be a second terminal post with no connection to it. Should there be a second high current lead to this terminal post as well?
I have tried to measure the winding resistance, but even with a good meter the resistance is too low to get a sensible reading.
It cranks evenly, but turns over slower than the book figure of 200 RPM, and the starter only draws 265A rather than the book figure of 450A (even so, it starts OK so it's not a major problem, I am just curious).
The battery and all the electrics are sound, by the way.
Oscar
01-28-2000 00:11:30
 Re: Super dexta starter motor in reply to Dave W, 01-25-2000 09:18:59
Which only illustrates once more that a really good battery is a necessity for starting up a tractor.
Just to make a comparison:
Power (in Watt) = voltage (in Volt) * current (in Ampere) = 12 V * 450 A = 5.400 Watt = 5.4 kW.
In Europe, domestic home voltages are 220 V. If I were to require a power of 5.400 Watt the current would have to be:
current = power / voltage = 5.400 / 220 = 25 A.
That kind of current would blow the fuses, as most household fuses are 10 Amperes, and some (on groups with dishwashers and other consuming appliances on it) are 16 Amperes. If the fuses would NOT blow, the electrical wires would heat up as a result of the high current passing through, and the house would more than likely burn down.
If it takes 10 seconds before the engine starts, the electric energy consumed will be:
Energy (in Joules) = Power (in Watt) * time (in seconds) = 5.400 W * 10 s = 54.000 Joule
It would take a regular 100 Watt lightbulb about 10 minutes to consume the same amount of energy, i.e. 50 times longer!
A tractor battery is a marvel in that it can deliver such enormous currents and power.
(all calculations based on a domestic voltage of 220V, as in Europe)
Brian
01-25-2000 11:59:34
Dave,
Where is the terminal with no lead connected? If it is on the front of the starter motor assembly, on the end face, it is a spare earth terminal. If it is on the solenoid next to the power terminal with no lead connected to the starter motor, your going to be a millionare cause you have discovered a new way to transmit electricity without wires ;)
regards
Brian
Dave W
01-26-2000 00:40:47
 Re: Re: Super dexta starter motor in reply to Brian, 01-25-2000 11:59:34
Damn it, I'm not going to be a millionaire. It's on the end face, so I guess it's the earth terminal.
