Fordson Tractors Discussion Forum
1959 Fordson Loader Backhoe
T.J.K. - MICHIG
12-27-2005 16:53:22
I just bought a 1959 Fordson Power Major Diesel. It has a very heavey duty built loader and a backhoe. I have not found any ID tags or info in the equipment. I would like to know what I have in order get the proper manuals. Posted pictures on Picture ID site. Hope someone can help. It has a front dirven pump - what grade hyd fluid should I use? THANK YOU
matt in pa
01-03-2006 10:25:40
 Re: 1959 Fordson Loader Backhoe in reply to T.J.K. - MICHIGAN, 12-27-2005 16:53:22
Looks like a Sherman hoe (Power Digger) to me, but I am not sold on the loader being Sherman. Looks like it could be a Johnson loader. Sherman Backhoe conversions usually have a the pump mounted where the belt pulley drum is located, although if that pump failed somewhere along the way I can imagine it being replaced with a front pump (much easier to adapt a new pump that find parts for the Sherman).
pacrat87
01-01-2006 18:05:11
back hoe is same desigh as mine SHERMAN, mine has manufacture tag rivited in center of unit above were the boom cylinder ataches to the backhoe frame should also have two oil line coming out of framein same area
Scott in PA
12-27-2005 18:09:34
I look at the pictures and I am not sure what make it is, but I can tell you that they are not Ford units. Ford's were ALOT heavier than the one ones you have. Believe me I KNOW.
I don't think they are Sherman either but i can't say for sure as i can't find the pictures i had of a sherman. If I find them I'll post them.
Good Luck
