Fordson Tractors Discussion Forum
super major value
joey douan
01-05-2006 20:35:30
I have a super major with high extensions on the wheels i picked up at an auction 15 years ago.
is this a rare or valuable tractor ? I don't know if everything is there or not we never tried to start it. I was told it would run on ether.value?
matt in pa
01-06-2006 08:26:07
 Re: super major value in reply to joey douan, 01-05-2006 20:35:30
I would have to agree with Majorman. Ether is the worst thing to feed these old girls.
Where are you located? I might be interested in the Super. I have access to another motor. I am in Northeast PA, USA.
Majorman
01-05-2006 23:59:08
A picture would be useful, and some idea of where you are.
If the engine requires ether to start and run it will be completely knackered and will reduce the value to nearly scrap price.
joey douan
01-06-2006 15:14:27
 Re: super major value in reply to Majorman, 01-05-2006 23:59:08
You are right about the ether..... they become addicted to it. I am a mechanic i don"t use the stuff. the auction guy said they had it running ,but you know how some of them are.If it would crank and run what kind of price range would it fall into ? the sheet metal is rough.
I am in lower South Carolina
matt in pa
01-09-2006 05:35:40
 Re: super major value in reply to joey douan, 01-06-2006 15:14:27
I have never seen a hi-crop version, so I haven't the faintest idea what you tractor might be worth. In this area I have seen good running, straight metal working Supers go for $2000-$3000. With the sheet metal in poor condition and the engine as it is, you are probably looking in the $500-$800 range, although this does not take into account the Hi-Crop. Good luck if you decide to sell. You should keep it and get it running correctly again. Best tractors out there!
Majorman
01-07-2006 02:25:17
Problem is, the value can vary so much. I have seen a good one, ex farm with good tinwork and a good runner, sold for £500.00 ($800.00),also seen them completely rebuilt and painted for £2000.00 ($3200.00).
Yours would have a rarity value over here and if a collector wanted it or some one could use the high clear then the price would go up but the engine problem would go against it. You could be looking to spend around £1500.00 ($2400.00) for new liners, pistons and crankshaft regrind inc. bearings.
