Fordson Tractors Discussion Forum
Major thermostat sticking.......
David in Ohio
01-12-2006 14:59:49
Thermostat is sticking in one of my 54 majors and I would like to know (Majorman) if I can just take it out and run without it. Hard to find a replacement here in Ohio and I don't use the tractor for heavy work. My 56 Ford 860 runs fine without a thermostat..... .
matt in pa
01-13-2006 06:16:33
 Re: Major thermostat sticking....... in reply to David in Ohio, 01-12-2006 14:59:49
David, I ordered a thermostat from Bareco for my 55, and it fit and worked perfectly. Can't remember how much it cost though.
David in Ohio
01-13-2006 18:46:27
 Re: Major thermostat sticking....... in reply to matt in pa, 01-13-2006 06:16:33
Thanks Matt, I'll get one.
Majorman
01-13-2006 00:01:24
David,
You should be OK without one. If it gets really cold I would blank off part of the radiator to keep her up to temperature.
David in Ohio
01-13-2006 18:45:22
 Re: Major thermostat sticking....... in reply to Majorman, 01-13-2006 00:01:24
OK. Thanks MM.
