Fordson Tractors Discussion Forum
How does the decompressor work?
FMD
01-17-2006 04:30:00
How does the decompressor mechanism work in a Fordson Major Diesel tractor? I have the front mounted lever type. I tried to figure out the mechanism but only conclusion I could achieve was that the rocker arm shaft is not straight and the rockers are attached to it somehow off centre. When the decomp. lever rotates the shaft the rockers are forced downwards a little bit thus opening the valves because the push rods prevent them moving in that end. Is that correct?
john savoy
01-18-2006 15:14:44
 Re: How does the decompressor work? in reply to FMD, 01-17-2006 04:30:00
you are correct,straighten any bent rods,lube all moving parts with a little machine oil and should work good luck john
