Fordson Tractors Discussion Forum
Fordson Pierce govenor
Bud Cronin
01-31-2006 19:24:55
Hi all
Im in the proses in restoring a 1929 fordson. It has the aftermarket Pierce govenor. But the linkeges are mesed up. I was wondering if anyone has pics and or info on how this thing was conected. Also any info on a serial number begening with a CT.
Thanks Bud Cronin WA
Butch Howe
01-31-2006 20:49:54
 Re: Fordson Pierce govenor in reply to Bud Cronin, 01-31-2006 19:24:55
Hi Bud, I think your Fordson may not be a 29'. The 29 Fordson would have a factory mag mounted on the right side of the engine and a built in magneto just forward and driven from the mag gear. The Pierce Governors were mostly found on the F model 1918-1928. Linkage for them can be a bit complicated as the rod goes back to the dash where it pivots over and connects to the trottle linkage. Unfortunately I don't have a picture for you. Maybe others can help. Look on this site for serial number information under research and info. There were no serial numbers starting with CT that I know of. Your serial # should be found just above the forward most manifold bolt on a flat just below the head. Hope this helps you a little, Butch
Bud Cronin
02-01-2006 06:49:44
 Re: Fordson Pierce govenor in reply to Butch Howe, 01-31-2006 20:49:54
Thanks Butch
This Fordson is a odd one. it could vary well be a 1928. Thanks for the info though. It has a english gas tank irish wheels and the trembler coils.the serial number is abuve the manafold and it does begen with a CT. I will get the number tonight and post it and maybe you could tell me the year. many thanks Bud
cdmn
02-02-2006 19:43:09
 Re: Fordson Pierce govenor in reply to Bud Cronin, 02-01-2006 06:49:44
Make sure it doesn't begin with 67XXXX. That would be correct for 1928's
