Fordson Tractors Discussion Forum
Dexta starting problem
botch
02-05-2006 07:03:23
when trying to start all I get is a single click then nothing. The starter motor doesn"t turn at all. It has a new battery and alternator but I note the charging light is now off when it is switched on with key. Is this just a blown bulb? I have checked the connections from battery to starter solenoid and checked the starter motor.Is this problem the solenoid or the relay switch on the starter motor?
Majorman
02-05-2006 10:47:08
 Re: Dexta starting problem in reply to botch, 02-05-2006 07:03:23
Think you will find the problem is a bad connection. Try the earth cable to block. This is the usual suspect if you have checked and cleaned the battery terminals.
Did you also check if the new battery had been fully charged when you fitted it?
botch
02-07-2006 12:23:38
 Re: Dexta starting problem in reply to Majorman, 02-05-2006 10:47:08
thanks for advice. I have checked the connections to starter,solenoid and starter relay with no luck. Thinking it is the starter solenoid rather than the starter relay? What do you think?
