Fordson Tractors Discussion Forum
I couldn't believe it!!
Oregonfarmer
02-23-2006 08:10:28
I took the top cover off my FSD because of lift problems and discovered that some one had removed the exhaust filter and valve! Only the pipe was left!
I have searched the net for the parts I need, but can't find any. Not sure if this is my lift problem, but can I run it this way?
Majorman
02-23-2006 08:41:07
 Re: I couldn't believe it!! in reply to Oregonfarmer, 02-23-2006 08:10:28
No. The exhaust filter and valve is critcal to the operation of the lift as the back pressure generated by them, works the unload valve. If the unload valve is not working properly, neither will the lift.
On the older Super, the exhaust filter was supported by a bracket from the pressure pipe. This used to break and drop the exhaust filter and pipe into the gears. A modification was done on later machines when the support was taken from a bracket bolted to one of the pump mounting bolts. Its worth checking to see if you need this bracket as well.
