Fordson Tractors Discussion Forum
Dexta hyd pump exhaust filter
Chaser
02-27-2006 14:05:34
Bought a Dexta on Friday w/ inoperable 3pt. Owner said it worked fine for 2 yrs and then quit after having it serviced by a NH dealer.
I drove it home (6 miles) and shortly found the inlet filter mesh was completely caked w/ congealed oil so I cleaned it all out and the 3pt works great (sorta jerky). But in the process I noticed the output filter (old Purolator w/ no p/n) is totally blocked and I'm sure the flow is only possible by the bypass valve.
Does anyone have a Purolator p/n for a Dexta hyd pump exhaust filter?
Thanks.
Chaser
Valdosta, Ga. USA
Stefan
03-15-2006 11:22:39
 Re: Dexta hyd pump exhaust filter in reply to Chaser, 02-27-2006 14:05:34
Hi Chaser,
the return filter is still available at your local NH Dealer. Ask for filter part# 81800792. And check out my website here:
http://www.fordson-dexta.de/501255938c00b4b22/501255954414d58fe/index.html
Oregonfarmer
02-27-2006 23:21:05
Purolator MF 178 is stamped on mine. I need one too, but haven't found one. No book I have gives a cross reference to Puro number.
Chaser
02-28-2006 12:36:41
 Re: Dexta hyd pump exhaust filter in reply to Oregonfarmer, 02-27-2006 23:21:05
NAPA said if I bring it in they'll match it up. I'll let you know what happens.
Chaser
02-27-2006 14:11:00
BTW, in the process of removing the exhaust filter I removed the snap ring that holds the check valve in place and lost the retaining washer that keeps the spring captured against the valve. I substituted a 1/4" flat washer as it fit quite snugly, but since the original item has left for parts unknown I"d like to know what I lost. Was it merely a washer or did it have some other profile that I should be aware of?
Thanks.
Chaser
