Fordson Tractors Discussion Forum
No Power
hahter
03-15-2006 15:35:28
My father has a 62 SuperMajor and is having problem with not having power out engine. When he puts tractor under load the engine dies. What could be the problem. The tractor has the vacumn type governor.
Thanks for the help.
matt in pa
03-17-2006 05:30:38
 Re: No Power in reply to hahter, 03-15-2006 15:35:28
Might want to check the hose between the air cleaner and the intake also. Mine went bad and choked off the engine quite efficiently.
Majorman
03-15-2006 23:42:26
Sounds like fuel starvation. Check/change the fuel filter and remove the fuel tap and clean the filter here.
Check the air cleaner too.
