Fordson Tractors Discussion Forum
Did all the Major work, and now it won't turn over
David in Ohio
03-18-2006 12:41:26
Pushed my 54 Major out into the sunlight today, ready to fire it up after a winter of restoration. New Lucas solenoid, new battery and starter cables, new Lucas switch on top of starter. Have not put in a new wiring harness yet, just a simple circuit from battery positive, to solenoid, to starter switch, to solenoid, to starter. It's negative ground with an alternator. When I push down the starter lever, the solenoid clicks ..... .. and that's all that happens. So what have I done? I'm cold and tired and a cup of tea will make me feel better, but what about my Major?
Hope you read this Majorman - answer has to be simple, I'm sure.
Majorman
03-20-2006 00:52:39
 Re: Did all the Major work, and now it won't turn in reply to David in Ohio, 03-18-2006 12:41:26
third party image
David,
I post them on my web site then copy the URL to here. I think it has to be from a web site not a photo album though. Could be wrong about that, I know more about Majors :0)
Majorman
03-19-2006 00:51:21
If the solenoid clicks you have it all working correctly but you have either a bad connection or the battery is not fully charged. Check all your connections from each battery post and down to ground.
David in Ohio
03-19-2006 04:02:53
 Re: Did all the Major work, and now it won't turn in reply to Majorman, 03-19-2006 00:51:21
MM, that's what I thought, and I did discover that I had a lockwasher on the starter post that was shorting across the post to the starter casing. Guess I need to put a non-conductive washer in there, recharge the battery and try again.....thanks for your advice as always. By the way, how did you post that image of your Major on to a site message? Best, David
