Fordson Tractors Discussion Forum
Super Major won't start
DLS
03-31-2006 11:09:44
I tried this earler and it did not post. If I am wrong,please forgive. My super major diesel will not start. The battery is hot, the starter seems to be working properly, the fuel pump has pressure,fuel is getting to the engine and i get grey smoke from the stack. The only starting problem i have ever had was when the tractor lines were not bled enough..i have done this repeadely..it will not start. Any suggestions to help solve the problem will be appreciated. Thanks
DLS
ford-s
03-31-2006 16:59:26
 Re: Super Major won't start in reply to DLS, 03-31-2006 11:09:44
Bud,it sounds to me your fuel injection pump may be out of time.Try this;pop the no.1 tube off of the injector,turn the engine over until fuel spits out of the tube,stop immediately,go down to where the flywheel is,back the f/w until you see the timing marks ,line up the marks(which are 23 degrees btc)go back up to the pump,loosen two bolts,and line the marks up,tighten the bolts,put the tube on the injector,bleed the one line,and she should fire up.I know this from experience.good luck,cw
