Fordson Tractors Discussion Forum
Power Major is Bleeding!!!
Adam Foster
04-04-2006 12:58:03
Hi I bought a 1958 Power Major a couple of months back, drove it home and left it alone really til i had some time. I started to play about this weekend and when it was running it leaked (Bleeding as my Dad calls it!) engine oil from both the front of the engine and from the bell housing. The front does not worry me too much as i dont have to split the tractor, however the bell housing leak does, as i am assuming it is the rear crank seal which has give up. Is it possible to split the tractor without a hoist? The next thing is i removed the rocker cover for inspection and found everything to be covered really nasty "tar like" oil, how do you guys clean things like that as i obviously cant use paraffin because of ruining the bearings. Any help or ideas on these matters will be greatly appreciated. Adam Foster.
Majorman
04-05-2006 00:32:12
 Re: Power Major is Bleeding!!! in reply to Adam Foster, 04-04-2006 12:58:03
Your leak from the front can be timing caover oil seal or front plate gasket. Check the post on "Main front Seal" below, I have posted pictures that will give you an idea of what you are taking on. It's no big deal but you will need a good jack and plenty of blocks of wood.
The same goes for splitting the tractor. I have done this hundreds of times so find it easy. We had a pair of wheels mounted on threaded rods and fixed in a frame, but not on rails. This went under the back of the sump and had two steady bars up to the front plate mounting bolts. this allowed us to push the engine and front axle away from the gearbox and move it anywhere in the workshop. I have also done the job using a tractor and loader, pallet forks and blocks and engine hoists, but I would never recommend using a trolley jack as these are too narrow and it is possible to drop the engine.
The bell housing oil leak can also be from the gearbox input shaft oil seal. Not a big job once you get the tractor split.
The tar like deposits in the engine are possibly best left until you carry out a major overhaul. Any attempt to clean them without dismantleing the engine can result in a clogged intake filter on the oil pump and starving the engine of oil. I would use normal diesel engine oil, work the tractor and change the oil and filters after short intervals. This will soften the deposits slowly and clean them out in suspension in the oil.
Be careful and plan your splitting jobs carefully to avoid any accidents and injury to yourself.
