Fordson Tractors Discussion Forum
majorman, re;engine swap
arrock
04-05-2006 08:40:30
looking to put an engine into a 1955 fordson major diesel(bought backhoe unit without motor, cant retreive any parts) found a fordson major serial# 1353999. were all perkins diesels?
would a super major or dextra motor fit? thx in advance eric
Majorman
04-05-2006 10:37:07
 Re: majorman, re;engine swap in reply to arrock, 04-05-2006 08:40:30
I would be a bit careful. Bob is correct to say all the engines used in the Fordson Major range were designed and built by Ford at Dagenham.
However some of the early tractors were converted from petrol/paraffin to diesel by fitting Perkins L4 engines. I have yet to come across one as all were exported from the UK as far as I know.
Any Major engine from 1952 to 1964 will slot straight in to your tractor although some may need a bit of modification to the throttle linkage. On early tractors the throttle passes through the block, on later ones it goes behind under the battery box.
Dexta engines will not fit.
Bob N.Y.
04-05-2006 10:11:42
The Major engines are NOT Perkins!
