Super Dexta
Jay Andrews (TX
01-28-2000 23:10:10
I have recently purchased a Super Dexta, On startup it surges from very low rpm up to 800-1000 rpm, just back and forth for about a minute or until it warms slightly. Is this normal for the Perkins? If I leave the preheater on for a bit, it seems to surg much less. Is there an adjustment that can help? I haven't delt with the diesel very much, mostly gas. Thanks..... Jay
Burrhead
01-29-2000 12:23:53
 Re: Super Dexta in reply to Jay Andrews (TX), 01-28-2000 23:10:10
That's more or less normal Jay. If it gets too bad or refuses to smooth out take the injector pump and injectors out and have them cleaned and set. It cost about $200 for it all done at Precision Injection on NE corner of McCarty and I-10 in Houston. If you know someone near you who has a test stand for the injectors they are simple to clean and check and adjust yourself.
