Fordson Tractors Discussion Forum
Message to majorman
daveywavey
04-17-2006 17:48:39
Hello, I got my lift to work on my FSM, I did as you said and took apart the valves on the lift cylinder, such as the "trumpet bit" and the piston using a fine threat bolt to retract it, rather that hit it out. They both were stuck, I cleaned them up, put new o rings and installed it. Now it works perfectly, VERY strong, and the lift stays up without dropping at all. I tested it on my bush hog and it worked flawlessly. I keep telling myself " I Knew there was a reason I chose a FSM over an 8N Ford. HAHAA Thanks Majorman, If only you got paid for your information, youd be rich.
