Fordson Tractors Discussion Forum
Major compression test
David in Ohio
04-29-2006 18:05:52
I have always had Ford gas (petrol) engines up til now and a compression test to find out how tight the rings are is easy. But how do I do a compression test on a diesel Major engine? One of my Majors lugs in 6th gear and the timing is right, so I suspect we have some wear in the rings. Your help (Majorman) is always appreciated.
J Schwiebert
04-30-2006 19:34:12
 Re: Major compression test in reply to David in Ohio, 04-29-2006 18:05:52
You need a diesel compression tester with the correct adapter. How does it start when cold? Before you get into that put the tractor on a Dynometer. It is money well spend. I used to work for another color dealer and it was a very good service tool. Where in Ohio? J
David in Ohio
05-01-2006 03:44:03
 Re: Major compression test in reply to J Schwiebert, 04-30-2006 19:34:12
Thanks for the good advice. Starts fine when cold, provided battery is fully charged. Am 15 miles east of Cincinnati.
