Fordson Tractors Discussion Forum
Fordson Serial Number
Jim Sutton
05-17-2006 16:05:08
My father-in-law has an old fordson I have no idea what the year or model it is. the only serial number I can find is on a tag above the carburator . can anyone give me some ideas. Thank you
Butch Howe
05-17-2006 20:49:01
 Re: Fordson Serial Number in reply to Jim Sutton, 05-17-2006 16:05:08
Jim, The Fordson serial number is found just above the front manifold bolt on a flat just below the head. It should be a six digit number unless it's real early. Sometimes it is very hard to read, may be rusted or painted over. Some engines don't have a number at all. Once you find it look on this site under "Research & Info" Go down to serial numbers and go to Fordson. Good luck and hope you find it. Let us know how you make out.
rustymich
06-07-2006 19:40:18
 Re: Fordson Serial Number in reply to Butch Howe, 05-17-2006 20:49:01
I thought it was a seven digit number till 62 if not can someone tell me what this number would be on the right side just before the front theres a plate or flat spot number 1620415 would be thanks for any help.
