Fordson Tractors Discussion Forum
Help! Which Perkins Fits SMD?
ex500
05-25-2006 10:46:50
Considering a re-engine on my SMD, Hoping someone has Crank centerline to Trans alingment pin dimensions so I can fabricate an adapter plate.
Any help would be appreciated.
ex500
09-21-2006 15:19:00
 Re: Help! Which Perkins Fits SMD? in reply to ex500, 05-25-2006 10:46:50
Thanks Guys, everything helps.
cdmn
06-07-2006 21:12:33
Some people put 6 cyl New Holland combine engines into them. Same bellhousing pattern. Lots of posts on this subject from a year or two back.
richard in nz
05-25-2006 23:44:57
The only conversion I know of which was a proper conversion pack prodouced by F.Perkins was to put the Perkins L4TA diesel in to a petrol or petrol/v.o. engined Major, not a diesel Major
EX500
06-01-2006 20:45:45
 Re: Help! Which Perkins Fits SMD? in reply to richard in nz, 05-25-2006 23:44:57
Thanks Richard, maybe that will produce some usable dimensions. Around here USA, rebuildable fmd's, pmd's, and smd's are hard to find. Figured a re-engineing was worth looking into. JB.
Mark1
06-12-2006 14:12:16
 Re: Help! Which Perkins Fits SMD? in reply to EX500, 06-01-2006 20:45:45
Has anyone looked into cutting an unusable or busted New Major engine block (that part of engine block area behind the last cylinder that bolts to the transmission) that is behind the #4 hole, milling it flat and true, then drilling it to fit another type block? Of course there is flywheel considerations and spacing to check too.
