Fordson Tractors Discussion Forum
darn dexta
chriscram
05-27-2006 17:19:57
combustion caps leaking-where leaking before. rebuilt head complete machine shop-replaced valves,seats,guides and checked if warped,I replaced combustion chamber covers new from ford-old ones where broken(thank you majorman)replaced steel gasket for cover"s with new,one seems tight other two have bubbles coming out around them.Is this a problem with these or am i screwing somthing up!have not replaced starter want to put in 3000 starter so I pop started it she started in about 3 feet ran nice???
Rick in NB
05-28-2006 10:44:04
 Re: darn dexta in reply to chriscram, 05-27-2006 17:19:57
Just been lurking around here, but had to ask: What are "cumbustion caps"? And exactly what do they do? Are they like injectors?
Thanks
chriscram
05-28-2006 22:05:22
 Re: darn dexta in reply to Rick in NB, 05-28-2006 10:44:04
covers to combustion chamber on side of head opp.intake,cover small chamber on top of piston .are below injecters
Majorman
05-28-2006 00:15:11
You may find that painting the gasket on both sides with aluminium paint then assembling it when wet and allowing to dry, will solve your problem. Its a pretty common one with these tractors.
