Fordson Tractors Discussion Forum
Fordson Major gas carb
Doug Smith
06-01-2006 17:55:45
My 52 major(gas) is running a bit rough, and I need to find a carb kit, or a replacement carb. The local New Holland dealer thinks he may be able to help if I can get him a little more info. All I know is that it is a Zenith Carb no info or serial # to be found. Doug Smith
FARM IDAHO
06-22-2006 10:02:12
 Re: Fordson Major gas carb in reply to Doug Smith, 06-01-2006 17:55:45
i have an old fordson major desal tractor that doesn't run so i dont know if the carb works i will check in to it and get back to you
Cal Leishman
06-10-2006 10:37:05
Hi,
I am having the very same problem with my 52 FM. What does your carb look like? Mine has a two bulb float which is different than the one pictured in the shop manual. I suspect it to be a replacement carb.
Cal
Miles
06-01-2006 19:44:49
Good luck with NH for a carb kit unless you are located in Europe.
I am in Canada and have looked for several years without success. Land Rover is a new lead which I will check.
A carb problem is sometimes hard to diagnose...
Is it flooding/black smoke? float needle, hole in float
Backfiring under load...Most likely lean?
air leak, plugged filter in tank, bad lift pump
This assumes nothing else has changed
Regards
kenneth armour
06-01-2006 18:57:21
woul dit be the same as a Series land rover, the 2.25 petrol engine carries a zenith.
Kenneth
