Fordson Tractors Discussion Forum
what weight oil?
botchit
06-13-2006 03:00:22
Oscars web page is great for most things Dexta but doesn't mention grades of oil for gearboxes,axles and engine. Am I right in using top quality car diesel sump oil? Can i use standard car gearbox oil in the 'box?
Majorman
06-13-2006 08:42:14
 Re: what weight oil? in reply to botchit, 06-13-2006 03:00:22
There should be copies of the Ford oil specs on Oscars site for all the tractors.
The oil you need all through the tractor is HD30 or a multigrade 15/40W. The systems were designed for a fairly low grade of oil as that is what was availabl at the time. Synthetic oils will cause seal problems in these engines, gearboxes and rear axles.
Majorman
06-13-2006 09:10:45
 Re: what weight oil? in reply to Majorman, 06-13-2006 08:42:14
The oil specs. are in "Questions and Answers", "What oil do I put in My Fordson".
