Fordson Tractors Discussion Forum
exhoust smoke
jan de monchy
06-20-2006 05:49:48
My Dexta from 1962 has recently been overhauled, it is fine now but one problem has not been cured and that is extreme blue smoke production when started in relatively low temperatures (above zero).Pre glowing does not help much.After a few minutes idling all is OK.What should/could I do??
jan.
Majorman
06-20-2006 08:55:23
 Re: exhoust smoke in reply to jan de monchy, 06-20-2006 05:49:48
It could be a number of things. You don"t say how big an overhaul. Some people fit rings and think that is it but a Dexta will need sleeving and boreing. Here ia a short list of other areas:
Worn valves and guides.
Worn valve stem seals.
Leak of diesel into intake manifold from primer pump.
Engine not run in and the rings have not bedded.
Wrong type of engine oil. Should be HD30 or 15/40W diesel engine oil. Synthetic could cause a problem according to my oil supplier.
Tractor needs hard work for a few days like ploughing, cultivating or bush hogging to get her really hot.
Air cleaner upper part blocked.
