Fordson Tractors Discussion Forum
Fordson Major Deisel
Simon barker
07-30-2006 22:01:41
I am new to tractors and am having a bit of trouble cold starting my fordson major diesel. Could someone please give me a suggested step by step. NB The tractor runs beautifully once going and is fine to restart, i think i am doing something wrong at the start.
thanks Simon
Simon barker
07-31-2006 15:58:35
 Re: Fordson Major Deisel in reply to Simon barker, 07-30-2006 22:01:41
Majorman your help is greatly appreciated. One last Question. The stop arm behind the cold start button. should it be sitting vertically when starting.??
Thanks Again i will leave u to more interesting and challenging queeries
Regards Simon
Majorman
08-01-2006 00:01:30
 Re: Fordson Major Deisel in reply to Simon barker, 07-31-2006 15:58:35
Should be leaning forward about 10 degrees.
Your welcome.
Majorman
07-31-2006 08:37:08
The only time you have to bleed or prime the system is when you run out of diesel or when you change the fuel filters.
Two bleeds on the top of the filter, in and out, one bleed on the pump under the fuel lines.
Slaken these off one at a time and prime until airfree diesel comes out. Then tighten carefully. Do not overstrain them as they will break.
The tractor also has a filter in the fuel tap under the tank. This may need cleaning if you get a lot of gunge in the tank. Drain the diesel and remove the tap. Clean filter on tap. Replace tap.
You will then have to carry out above.
Majorman
07-31-2006 00:05:13
Throttle halfway,
Push in cold start button in the centre of the stop control on the injection pump.
Push starter.
Even if the engine is worn they will usually start straight away.
If someone has been adjusting the pump timing or using ether then you may have problems.
Simon Barker
07-31-2006 04:28:48
 Re: Fordson Major Deisel in reply to Majorman, 07-31-2006 00:05:13
Thanks, i was unsure about undoing the nut to get rid of any air before starting. I was also wondering when i need to prime the glass bulb pump. Could you please advise.
Thankyou it is greatly appreciated.
Simon
