Fordson Tractors Discussion Forum
'Greasing rear wheel bearings' on a Super Major
Kjetil
08-18-2006 12:15:48
When I grease, excessive grease usually comes out somewhere, and I use it as an indication for a successful grease job.
This is not happening on the rear wheels, and I am afraid of not being able to grease at all, or the excessive grease may go to the internal of the 'rear end'.
What is your experience when greasing the back wheels?
Any comments welcome
Majorman
08-19-2006 00:47:34
 Re: 'Greasing rear wheel bearings' on a Super Majo in reply to Kjetil, 08-18-2006 12:15:48
Do not overgrease them. A couple of pumps every three months is all they really need. The oil from the axle gets up there too and the grease is just to make sure they have some lubrication.
Kjetil
08-19-2006 03:39:05
 Re: 'Greasing rear wheel bearings' on a Super Majo in reply to Majorman, 08-19-2006 00:47:34
Is it ‘wide’ open from the 'rear wheel bearing' and into the axel?
I pumped a lot of grease in there. Should I worry?
Thanks for your help so far.
Majorman
08-19-2006 09:38:43
 Re: 'Greasing rear wheel bearings' on a Super Majo in reply to Kjetil, 08-19-2006 03:39:05
Yes, but no worries, its a massive chamber.It won't hurt to have a bit of grease in there. It'll just be messy when you have to replace the seal if it ever leaks.
morningwood
08-18-2006 18:29:08
Usually just give her 4 - 5 squirts every or every other use. I agree with you it is hard to tell how much grease to put in. My tractor has the wheel weights on the inside so it is escpecially hard to tell for me.
Scott
