Fordson Tractors Discussion Forum
Oil filter cross numbers
Davewavey
08-23-2006 14:50:46
I need to get a new oil filter for my 62 FSM, but I dont want to wait a week or more every time to order a new one, SO..... .
Does anyeone know any Fram, STP, Wix or Bosch oil filter cross over part numbers? Any help will be appreciated
Thanks!!!
davewavey
08-24-2006 17:46:34
 Re: Oil filter cross numbers in reply to Davewavey, 08-23-2006 14:50:46
I got a wix 51188 today at oreilly;s auto parts. Its a little different, but it s a short filter like my old one is, no the long one, so I got the right one. Its smaller in diameter than the one I got from here on YTMAG. But its the same heighth exactly. I installed it and the new rubber seals and PERFECT!!!, my oil pressure was 10 psi, now its almost 25, that tells me my filter was clogged badly... THANKS again guys!!! your a lifesaver....or atleast a time saver!
woodache
08-23-2006 21:28:44
 I get mine from Re: Oil filter cross numbers in reply to Davewavey, 08-23-2006 14:50:46
I get mine from NAPA i just dont have the number handy, but watch any oil filter any one hands you there are 2 different ones with the same numbers one is long the other short you need to check yours to see which it is.
Oh if you look in parts books if you cant find it under ford look at New Holland
Farmer Ryan from WI
08-23-2006 18:59:49
Wix 51188
Fram CH813PL
davewavey
08-23-2006 20:43:44
 Re: Oil filter cross numbers in reply to Farmer Ryan from WI, 08-23-2006 18:59:49
Thanks!!! I appreciate your help. Ill try to track those down asap, Ill try a few parts stores and see what I can find. thanks Again!!
