Fordson Tractors Discussion Forum
Transmission vent
BrentReynolds
09-05-2006 19:13:02
Does anyone know where the vent is on the main transmission of a 53 major diesel. I just had the tractor split and replaced the rear transmission seal and completely resealed the rear differential assembly. Now that the transmission oil doesn't leak into the diff and you check the trans oil warm (disced for 1/2 hour) the oil will spill out with the fill plug removed. It also leaks out the pulley seal and input seal (I don't want any oil on the clutch)
going to split and reseal the front half next year. Thanks for any help.
Majorman
09-06-2006 23:39:41
 Re: Transmission vent in reply to BrentReynolds, 09-05-2006 19:13:02
If you go to Link and look on the Bulletin Boards for Major, a post from Dom about his tractor shows a picture of his steering box. In the background is a lovely shot of the bolt you are looking for.
Majorman
09-05-2006 23:00:57
Its a long-headed bolt just above the pulley that hold the battery support on.
