Fordson Tractors Discussion Forum
unknown typ tractor
jeff wheaton
09-09-2006 20:29:25
i need any help i can get on identifying this desal tractor its original color was blue leading me to believe its a ford but there are no identifying numbers under the several coats of paint iv scraped off other than the following numbers,on the injectors it has sims pe3a605593 under the manafold it has the number 00280096f,,on the motor block the number 1431605,,on the gear box the number d300 ento 957e7005 any help in identifying this tractor would be greatly apretiated thank you
Majorman
09-10-2006 01:16:06
 Re: unknown typ tractor in reply to jeff wheaton, 09-09-2006 20:29:25
Sounds like you have found a Fordson Dexta. Check behind the starter on the flange. There will be a number stamped down the flange which will give us some idea of the year and month of production.
The engine is a three cylinder Fordson/Perkins, a colaboration between the two companies. Parts are still available.
This is a handy, tough little tractor.
