Fordson Tractors Discussion Forum
Hey Majorman
Carl Porter
09-10-2006 14:14:12
How do I identify the front of a Tisco piston for a Super Dexta? Or does it make any difference? Thanks
richard in nz
09-12-2006 00:25:01
 Re: Hey Majorman in reply to Carl Porter, 09-10-2006 14:14:12
under the piston on the boss for the piston pin there is usually a raised piece about 1/8" wide by about 1/2" long, hopefully the tisco pistons will have it aswell and it goes to the front of the engine.
Majorman
09-11-2006 00:16:18
Carl,
Don't know about Tisco pistons but normally Dexta pistons should be marked before they are removed from the rods if you are going to use old ones. New ones have no marking and can be fitted either way.
If the Tisco ones have a split skirt, normally this should be fitted opposite to the thrust.
