Fordson Tractors Discussion Forum
Service 1954 Fordson Major Diesel
devondom
10-11-2006 03:26:01
Hi
I need to service my 1954 Fordson Major Diesel but get conflicting
advice about which oil to use. Is the following list O.K.
Sump and Air cleaner - 20W/50
Gear box, Rear Axel, Steering and Hydraulics SAE90.
Also I would like new filters for the fuel and oil as well as
new seals for the diesel lift pump. Can anyone recommend a U.K.
(South of England) supplier?
Thanks
Dominic
ftraders
10-19-2006 02:31:34
 Re: Service 1954 Fordson Major Diesel in reply to devondom, 10-11-2006 03:26:01
I'm just doing my first service on a 54 Major. I've just used caltex agri MP Plus in the transmission and rear end and castrol RX in the engine, it's best to check on there web site first(>Link
I've used ryco filters through out.
This is what it has cost so far in Australian $
Service
Fuel Filter: Top filter Ryco R1106P $19.20 16/10/06
Bottom Filter Ryco R2004P $11.65 17//10/06
Engine Oil Filter: Ryco $27.70
Power Steering Oil: Penrite Dex111 4L $21.70 16/10/06
Engine Oil: Castrol RX 20L (uses 7L) $96.60 16/10/06
Transmission Oil: Castrol Agri MP Plus 20L $100.40 16/10/06
Rear End Oil: Castrol Agri MP Plus 40L $200.80 2/10/06
Majorman
10-11-2006 08:59:58
You can use the same oil in everything if you like though I would have gone for a straight 30W diesel engine oil. Fordson specifications changed in 1959 and although 90W is still OK over here, so is the lower W rating.
Vapormatic and Sparex still do filters and lift pump parts. Google them for your nearest dealer. Old Fordson dealers or Case New Holland dealers may still hold parts.
There are no seals as such in the lift pump, only a diaphram which, if faulty, will let diesel into the sump.
Try Link There is lots of information on there specific to Majors.
