Fordson Tractors Discussion Forum
boat-motor fordson?
hans-joachim ge
10-13-2006 10:36:47
hello
i just bought an old motor-boat which has a four-cylinder-diesel-engine.the pre-owner says it has
50 hp,but could not tell me,who made it and there is no label on it.i think it is a fordson tractor-engine.who can help me and tell me the exact type and where i can get parts for it?
on the cylinder-head stands MONOCYL and under this: G N K 144?/ E 25 J /0290037
on the block:
0280103
C_KN_2A
D 20 1
maybe there are numbers wrong,because of rusting.
if you tell me your e-mail-adress,i will send you
photos.my adress:winston1306@freenet.de
thanks and greetings winston
Majorman
10-14-2006 00:22:08
 Re: boat-motor fordson? in reply to hans-joachim gelhorn, 10-13-2006 10:36:47
The numbers you post are not totally correct but it could be a Super Major engine from April/May 1963.
Has it got a Minimec injection pump? Injectors inside the valve cover? A picture would be useful.
HANS-JOACHIM GELHORN
10-14-2006 10:49:28
 Re: boat-motor fordson? in reply to Majorman, 10-14-2006 00:22:08
hello majorman
thanks a lot for your quick reply.the injectors are outside on the head.i do not know,how to load up pictures in this forum,please give me your e-mail-adress,so i can send it to you.my adress:winston1306@freenet.de
thank you and greetings from germany.winston
Majorman
10-15-2006 01:01:51
 Re: boat-motor fordson? in reply to HANS-JOACHIM GELHORN, 10-14-2006 10:49:28
If the injectors are outside the valve cover it will not be a Fordson tractor or industrial engine before 1965. Afraid I cannot help further.
