Fordson Tractors Discussion Forum
front axle pivot bracket
charlesmacleod
11-14-2006 02:14:46
The bushing is completely worn through , I can see this without dismantling it, what is the easiest way of repairing it ( busy farmer)Can I fill up the gap behind the new bushing with weld from a MIG ? Braze? Molten lead? Can one buy / make an oval bush?
This must be a common problem .
supergrumpy
11-15-2006 11:37:30
 Re: front axle pivot bracket in reply to charlesmacleod, 11-14-2006 02:14:46
I caught the bushing on my MF135 before it wore too far into the axle, teeny bit of gap behind the bushing but after 3 years its still AOK
there was room to double bush (one facing from each side) so maybe thats what is holding it, MF only put a rear bushing in
Filling gap with lead doesn't seem like good idea as lead might flow out under all the pounding
