Fordson Tractors Discussion Forum
Where is the Major regulator?
david in Ohio
11-15-2006 13:58:25
My 1954 Major isn't charging. Where is the regulator located? Should it be inside the dashboard box?
morningwood
11-18-2006 16:40:39
 Re: Where is the Major regulator? in reply to david in Ohio, 11-15-2006 13:58:25
third party image
The regulator is the blue box located to the right of the air intake. I should have a cover on it that you can take off and you will see a bakelite regualtor with wires coming out of the top and the bottom. The above is a aftermarket unit, yours should be similar to B5253.
You might wanna make sure your generator is putting out enough juice. You should be able to test it with a volt meter. Unless your tractor has been changed it should be positive ground.
After I hooked my genny back after it was rebuilt I was seeing approximately 13 - 13.5 volts coming in on the battery.
Scott
david in Ohio
11-20-2006 14:55:55
 Re: Where is the Major regulator? in reply to morningwood, 11-18-2006 16:40:39
Thank you all. I have never really understood tractor electrics - am just not wired that way. Will fit a new wiring harness and then test regulator and generetor to see what happens. David
souNdguy
11-16-2006 12:23:14
Follow your field and or armature wires.. they have to hit the regulator...
Soundguy
CENTAUR
11-16-2006 20:50:09
 Re: Where is the Major regulator? in reply to souNdguy, 11-16-2006 12:23:14
Did they perhaps use a third brush generator which might be ajustable?I have to confess I know nothing about them majors.Some one know? CENTAUR
souNdguy
11-17-2006 10:38:50
 Re: Where is the Major regulator? in reply to CENTAUR, 11-16-2006 20:50:09
I don't know either.. but even if it was a 3rd brush.. it would have a cutout inline with the armature..
Soundguy
