Fordson Tractors Discussion Forum
major two stage clutch
mike jenezon
12-10-2006 21:51:15
Hi did any majors or power majors have 2 stage clutch if so can you tell on one that dosn't runwithout taking it apart thanks mike
Grabatire
12-17-2006 18:46:41
 Re: major two stage clutch in reply to mike jenezon, 12-10-2006 21:51:15
Another way to determine the difference is to measure the distance the clutch fork pivot shaft is from the front of the transmission. On a two stage tractor it is about 1,1/4" further back to allow for the deeper/thicker pressure plate assembly. For that reason a two stage clutch will not work in a single stage transmission housing. I learned the hard way.
R wooley
12-13-2006 17:42:35
Fordson Majors with 2 stage clutch can be determined by the HI/low shift lever.
hi/low lever up low range =single stage
hi/low lever up high range= 2stage you have to be able to drive tractor to determin
wich position move you at higher speed.
myassitis
12-11-2006 06:28:32
Here goes:
Engage your PTO. With your transmission in gear you should not be able to turn your PTO shaft by hand. Then press your clutch in about half way. With a dual clutch you should now be able to turn your PTO shaft by hand. Pressing the clutch all the way in your wheels should turn. Of course to test that your tractor whould need to be jacked up. My 1957 Fordson Power Major has the two clutch system which went bad. I had it professionally rebuilt for $800.00. Best tractor ever made in my opinun.
Myassitis
woodache
12-11-2006 22:53:14
 I agree best tractor Re: major two stage clutch in reply to myassitis, 12-11-2006 06:28:32
I agree the best tractor made for their Era with a undeserved bad reputation, But then again lets just keep it a secret so that we can still buy them at a resonable price, sometimes cheap, ;)) a real good oldie that is still affordable. With tech advances way ahead of its time
