Fordson Tractors Discussion Forum
fordson identity?
Hilltopper
12-13-2006 11:05:16
A friend brought me his tractor to work on. He had said it was a ford 2000 super dexta English. It has Super Dexta on the grill, however on the Hood it says Fordson Dexta. The manual that he has says Ford Dexta. I was wondering where the serial number is located on this tractor. It is a diesel with 2 stage clutch.I am new to old fordsons. Thanks for your help. Ps what lube is used in the tranny?
woodache
12-13-2006 20:38:20
  Years ?Re: fordson identity? in reply to Hilltopper, 12-13-2006 11:05:16
If it is a 64 it is a true Fordson Super Dexta Badged as a a 2000 Super Dexta 2000 if it is 65 or later it is a Ford badged as a Super Dexta. In the true English Dextas use 30wt motor oil in the trany and rear end. If it it a Ford 65 or later see specs for Ford tractors. True Dexta have Mimiac Simms injector pumps. English Fordson Dexta use the Ford/Perkins 3cyl 154ci diesel engine. Newer models use a Ford engine.
