Fordson Tractors Discussion Forum
Is injector pump interjangeable?
dwol
12-22-2006 08:39:07
Does anyone know if I can use an injection pump off of a super major on a reguar major? I think it is a Simms type, and the tractor is a 50"s model, not sure of the year.
Thanks
sandymac
12-22-2006 09:13:50
 Re: Is injector pump interjangeable? in reply to dwol, 12-22-2006 08:39:07
As long as its not the pump from the latest type super majors it will work, also i think that earlier majors had diffrent fittings on end of vacuum pipes from manifold to end of pump, but you can change the end housing of the pump if need be.
dwol
01-01-2007 08:10:49
 Re: Is injector pump interjangeable? in reply to sandymac, 12-22-2006 09:13:50
Thanks, Sandymac
