Fordson Tractors Discussion Forum
dextra vacume diaphram
jthomp
01-21-2007 09:02:19
tractor started running at high rpms ,could not idle it down .First checked the vacume line going to the simms pump it was good ,then i took off the cover and found the vacume diaphram is busted can anyone tell me how to get the diaphram out it is hooked to the shaft on the pump. and where i can order a new one if you have a phone number that would be great thanks jeff
JD dozer mike
01-24-2007 09:17:16
 Re: dextra vacume diaphram in reply to jthomp, 01-21-2007 09:02:19
Were you able to open the file ok?
JD dozer mike
01-21-2007 16:44:41
Email me, ill send you a fullpage scan from my IT book
micahwinn@yahoo.com
