Fordson Tractors Discussion Forum
Possible Cracked Head Gasket
morningwood
01-26-2007 08:35:49
You might wanna check the head gasket. These tractors are notrious for head gasket issues with the original copper head gasket. You can get a newer style one from bare-co.com.
If the head gasket checks out okay I would then check how high the liners are protruding from the block. If the tractor was over hauled previously and the liners were not set right that might explain your oil in the radiator fluid.
As others have said the air filter will get plugged with a grease like substance. I cleaned mine this past summer using kereosene. I soaked it in kerosene over night and the blew it out with compressed air.
If you check out the link I posted below you will see a situation similar to yours.
Scott
