Fordson Tractors Discussion Forum
oil leak
Hilltopper
02-10-2007 19:54:45
My Super Dexta seems to be leaking tranny oil around the clutch shaft on the right side. It started doing it after I filled the tranny to the check plug level on the right side. It has not been driven,but is sitting in my shop. I have been remodeling our kitchen for 2 weeks and have been away from it. Today I noticed an area about 3 foot square of fresh oil on the floor. I do not understand how it could leak out of the clutch housing unless something is bad wrong for the drive shaft seal should be above the oil level.There should be no oil in this area. Any thoughts?
WayneB
02-12-2007 11:53:16
 Re: oil leak in reply to Hilltopper, 02-10-2007 19:54:45
Look at the fourth through the sixth picture down, you'll see the input shaft outer plate. If it wasn't torqued and laced right, it could leak.
Wayne
Hilltopper
02-12-2007 12:31:20
 Re: oil leak in reply to WayneB, 02-12-2007 11:53:16
Thanks for your reply.I hope to get back to the tractor later this week.
