Fordson Tractors Discussion Forum
confused
ford-s
02-19-2007 16:43:17
the no. under the no.1 injector is;c-678901,this is subposed to be the serial no.,but I can't find a listing.for a fordson.help would be appreciated,cw
woodache
02-19-2007 19:42:51
 Here is the place Re: confused in reply to ford-s, 02-19-2007 16:43:17
Go Here
Link
ford-s
02-20-2007 16:20:57
 Re: Here is the place Re: confused in reply to woodache, 02-19-2007 19:42:51
i have been there woodache with no results,it seems the no. as listed does not exist,but everything points to it being a '59-'60 fpm.any more suggestions will be appreciated.
tiresntracks
02-20-2007 20:08:30
 Re: Here is the place Re: confused in reply to ford-s, 02-20-2007 16:20:57
I beleive that serial number means that your engine was replaced with an industrial one at some time. You will have to look for casting codes on other parts of the tractor to find out when it was made.
ford-s
06-07-2007 16:20:29
 Re: Here is the place Re: confused in reply to tiresntracks, 02-20-2007 20:08:30
guys i have learnd that my tractor is a power major with an industrial engine.i found out that the hydraulic lift is located in a different position than say a s/major.it is almost under my right knee,instead of on my right side.i acquired a parts tractor from a man down south.
