Fordson Tractors Discussion Forum
dexta pump gasket
Hilltopper
03-25-2007 16:08:53
My Super Dexta is leaking oil under pressure at the top of the hydrulic pump gasket on right side of hydrulic housing where pump attaches to housing. I am concerned this may be a complicated process to replace the gasket. Any one have any suggestions? thanks
Jim Boettcher
03-26-2007 09:53:14
 Re: dexta pump gasket in reply to Hilltopper, 03-25-2007 16:08:53
No big deal. Buy some gasket material approximatly same thickness (close is good enought). Clean old material off pump plate/valve body and using a small ball pein hammer make yourself a new gasket. Use the hammer lightly on soft/aluminun metal. Pein the bolt holes first so you can put in bolts to keep material from slidding around. I've even used old wax milk cartons with 100% relieability when in a fix. Doesn't pay to go to a dealer and pay $40.00 for a 50 cent gasket even if they could get one. Been doing this for over forty years with no problems.
Myassitis from Missouri
