Fordson Tractors Discussion Forum
SLEEVE SHIMS
DAIREL
04-23-2007 21:41:55
I AM REBUILDING A 1958 FMD. ONE OF MY SLEEVES ARE NOT STICKING UP ABOVE THE BLOCK. DOSE ANYBODY KNOW WERE I CAN GET THE SHIMS NEEDED TO RAISE THE SLEEVE UP. THANKS
R. Wooley
05-04-2007 07:15:30
 Re: SLEEVE SHIMS in reply to DAIREL, 04-23-2007 21:41:55
I bought a roll of .006 shim stock and cut it with good scissor when I did mine
tiresntracks
04-23-2007 23:17:19
The sleeves only need to protrude above the block .002 to .004". My Case/New Holland dealer was able to get shims for me. They only have one size, .004", for about ten bucks apiece. The part number is E194Z5.
W R
04-24-2007 02:31:21
 Re: SLEEVE SHIMS in reply to tiresntracks, 04-23-2007 23:17:19
Make sure the sleeve height above the block is correct, if it is not you will experience frequent blown head gaskets. Shims should be available from your dealer.
Sometimes the block may have to be machined.
