Fordson Tractors Discussion Forum
0 oil pressure
DWol
05-14-2007 10:23:13
0 oil pressure. Any Ideas as to whats going on? I replaced the oil pump, but still nothing? Any Ideas, this engine runs well, just no oil PSI.
john_bud
05-16-2007 07:07:44
 Re: 0 oil pressure in reply to DWol, 05-14-2007 10:23:13
While I haven't seen the inside of a FMD, there are only a few things that can be wrong. The most common one hasn't been mentioned. The pickup tube or the screen head may be cracked. Some times, the tubes may even rub on something and wear a hole.
It does no take much of a hole to allow the machine to suck air instead of oil.
jb
Dwol
05-16-2007 08:21:06
 Re: 0 oil pressure in reply to john_bud, 05-16-2007 07:07:44
The tube looked good, it has a bolt holding it to the middle of the center cap, so it can't move arround or rub on anything. If I take the pan off again, I'll give it a much closer examination, but I did not see anything wrong when I swapped the pump.
El Toro
05-15-2007 16:51:12
I think you need to blow out your oil pressure line that's been suggested. Did you prime the new pump before installing it? Hal
dWol
05-16-2007 08:15:17
 Re: 0 oil pressure in reply to El Toro, 05-15-2007 16:51:12
I did not prime the pump, I was told that the new oil pump would self prime. I don't believe that is the problem, but I think you might be right about blowing out the lines. Not sure what the best way to do that is. I don't want to blow out any gaskets or hurt anything when doing it.
El Toro
05-16-2007 08:44:13
 Re: 0 oil pressure in reply to dWol, 05-16-2007 08:15:17
I would remove the oil pressure line from the engine and blow it out. Are you getting plenty of oil to the rocker arms? It's a good idea to prime a pump a pump before installing on the engine. Hal
jboettcher
05-15-2007 07:01:02
Sir
Sounds like you may have the line plugged up with gunk. If you replaced the pump and still no pressure check the oil line to the gage and the gage itself. Those are positive displacement pumps and if they turn and if they have oil at the sump, they will pump. I'll assume you checked, cleaned and installed all correctly?
Fordson owner from Missouri
dWol
05-15-2007 11:24:13
 Re: 0 oil pressure in reply to jboettcher, 05-15-2007 07:01:02
You may be right, I am going to remove the filter and filter assembly next and see if there is any gunk arround or causing blockage. After that, I'm running out of options, and a rebuild is probably in order.
CENTAUR
05-14-2007 11:35:54
Did you use a real oil pressure gauge to come to your (0psi)? CENTAUR
dwol
05-14-2007 12:26:08
 Re: 0 oil pressure in reply to CENTAUR, 05-14-2007 11:35:54
Lets put it this way, the guage reads 0. So I took the guage off, left the port completely open, and turned her over. Nothing comes out.
CENTAUR
05-14-2007 12:40:43
 Re: 0 oil pressure in reply to dwol, 05-14-2007 12:26:08
I do not think you have told the forum what kind of (FORDSON) you got.There are some very knowageble guys out here that can help if they know exactly what you have.I am not one of them. CENTAUR
Dwol
05-14-2007 12:56:57
 Re: 0 oil pressure in reply to CENTAUR, 05-14-2007 12:40:43
You are right. Sorry bout that, its a 61 FSMD.
