Fordson Tractors Discussion Forum
Removing the Simms Injector Pump
Lute
05-21-2007 19:53:10
How do you go about pulling the pump off of a Super Major? After doing all the obvious things, like lining up the marks and removing the fuel and injector lines? Any pitfalls to avoid? I doubt this pump has been removed for 30 years or more.
ford-s
05-22-2007 14:30:12
 Re: Removing the Simms Injector Pump in reply to Lute, 05-21-2007 19:53:10
be sure that the timing mark on the flywheel,and the timing mark on the pump line up properly.
hectorgemme
05-22-2007 02:51:24
I think you have to removed the 4 screw at bottom bracket under the pump
