Fordson Tractors Discussion Forum
SUper major backfire
DAvid Newland
06-01-2007 18:03:24
I discovered I had a plugged fuel filter the hard way, I ran the engine out of fuel. I have since changed the filter, bled a bunch of fuel out of the tractor, and actually got it to run, but it is not running well, and will not keep running, plus it backfires a lot.
Is it possible that I just need to keep bleeding it? I did notice that there is a small air bubble in the glass dome over the pre-filter. Or, is it possible that I somehow affected the timing of the tractor? If so, where do I go from here.
I am not a mechanic by any means, although I can get through the basics.
Any suggestions?
Thanks,
David J. Newland
pcs
06-08-2007 18:35:52
 Re: SUper major backfire in reply to DAvid Newland, 06-01-2007 18:03:24
it may be the coupler in front of the injector pump got loose and the timing got out of whack
dwol
06-06-2007 14:02:33
The air bubble is not the problem. Could be timing, but if it was set before than it should still be set. Check your air intake. May be plugged.
