Fordson Tractors Discussion Forum
super major wont idle
pcs
06-08-2007 18:44:19
I had a major with a simms pump,but i was told it was a early one that was lubed by the engine oil,My cousin had a super major that i guess has its own oil for lube but he didnt know that.Well anyways he found out to late that it went dry, and now the tractors rpms will creep up when at an idle,and will not throttle down untill you almost kill it with the fuel shut off.Any imfo would be of help.They are a awsome tractor and I wish I still had mine..Thanks Pete
cowman1
06-09-2007 05:58:05
 Check For Re: super major wont idle in reply to pcs, 06-08-2007 18:44:19
Sounds like he has the vacum gov pump which is self oiled by fuel. Check the vacum lines for leaks if they are good check the gov for leaks. The cutoff rack also gets dirty and sticky. Remove the back cover with 4 screws clean and lube in place. Now if he has the Mechanical gov I cant help ;((
