Fordson Tractors Discussion Forum
Tire Pressure
James White
06-19-2007 14:00:06
This has probably been asked before but; how much air pressure should I run in 600x16 tube type tire on the front of my 1960 Dexta? And is it ok to put water in them for added weight? Thanks!
dlplost
06-20-2007 08:08:08
 Re: Tire Pressure in reply to James White, 06-19-2007 14:00:06
we run about 25psi, and windshield washer fluid.
George D.
06-20-2007 21:09:28
 Re: Tire Pressure in reply to dlplost, 06-20-2007 08:08:08
Good advice about the windshield washer fluid. Not nearly as caustic as Calcium Chloride (so fewer problems with severe corrosion if you spring a leak). Just make sure you get the stuff that's rated to -20 degrees F so you won't have any freeze problems in the cold months.
