OK, I took a look at your photos. Thought that the tractor looked familiar; turns out it was eBay #320113961724, which ended with no bidders and a starting bid of $2300... Was hoping that Butch Howe would see your query and chime in with his vast accumulated knowledge, but since he hasn't, I'll risk putting my foot in my mouth! Right out of the gate let me say a few things: First, I'm by no means an expert; Second, Remember that advice is often worth exactly what you pay for it (i.e., nothing). Lastly, I'm not trying to nit-pick your tractor, just give you some info that you may not have. OK, that said, I'm not seeing a lot of early features on this tractor. Yes, it has the early dash without fender holes and without the crankcase ventilator. The fuel tank is the single-bung type that was used through June 1924. I couldn't see the tank end in your photos, but early tanks were embossed with "Henry Ford & Son, Dearborn, Michigan USA". Tanks with "Fordson / Made by Ford Motor Company / Detroit, Mich USA" are post-1920, I believe. Oil filler is indeed the early "mushroom" type. Now that you have a magneto, the coil box is redundant. It is not the early keyed style, but is the intermediate "rainbow" type that was used into the mid-20's. You can keep it on there for looks (you can buy a lid to fit it; write if you need to know where), or you can take it off completely; it's up to you. You already mentioned the wheels: The rears are the later 7-spoke style (and while I'm on the subject of the rear wheels, let me say I think that the seller is full of beans when he said in his eBay listing that the rears had never had lugs, that they were canvas-covered -- I never heard of such a thing!), and the front wheels are also the later style, which have a flange on the outside of the rims and have the later style hubcaps. The rear wheel bushings are the later-style butterfly type and not the early round style. The rear axle is of the later style that has grooves to accept fenders. (I think this feature was introduced in 1920.) The drawbar is the later 5-hole type and not the early 3-hole variant. The belt pulley appears to be from a much later N-series tractor. The original 1-gallon gasoline starting tank is missing. The manifold is a later replacement. Curiously, the radiator topper and hand-nut, which were present in the auction listing photo, are missing from your photos; did they come with the tractor? That's about all I could see in the photos; again, I wasn't trying to nit-pick your tractor. My advice: Work with what you've got. You will certainly be able to make a nice project and have fun doing it. Don't worry about the year of manufacture. Almost all Fordson F parts are interchangeable, from 1918 through 1928 (and some even later into the N-series), so the concept of a "Franken-fordson" isn't new. It's still a good start of a project, it just isn't a pristine early-early F. Hope this has answered some of your questions and not raised too many new ones. -- Geo. D.
