Fordson Tractors Discussion Forum
Fordson gears
dana fields
06-26-2007 11:33:57
My tractor ran out of diesel and I pulled it back down the drive because the starter went out after I added more diesel. My guy put the new starter on and somehow the main gear is now not wanting to move. It's stuck in neutral. Is this something I did pulling the tractor? Any ideas?
Capp
06-30-2007 20:23:23
 Re: Fordson gears in reply to dana fields, 06-26-2007 11:33:57
I know this may be a stupid question, but is your low range and high range shifting lever in the middle. If it is then it won't got either way.
Capp
dana fields
07-02-2007 07:58:36
 Re: Fordson gears in reply to Capp, 06-30-2007 20:23:23
My low/high lever will move to either low or high. It doesn't appear to be affected. I will check to be sure but I think I left it in low since that is where I usually use it. I appreciate any help.
James White
07-03-2007 20:13:40
 Re: Fordson gears in reply to dana fields, 07-02-2007 07:58:36
Pull the top plate off the tranny and line up the shift dogs. The ball on the end of the shifter get worn and will hang between gears.
dana fields
07-12-2007 14:13:01
 Re: Fordson gears in reply to James White, 07-03-2007 20:13:40
Thank you so much. If it will ever stop raining here so I can work on it. I appreciate the advise.
dana fields
07-16-2007 14:14:20
 Re: Fordson gears in reply to dana fields, 07-12-2007 14:13:01
Easy as could be! Thanks
